No brakes after replacing master cylinder
1994 MERCURY VILLAGER
190,000 MILES • AUTOMATIC
CHRISTIAN GETZ
Had this van in the shop for three weeks now and I have never had such a problem. Replaced master cylinder along with all new hoses and bled countless times and still no brakes. I can pump the brake six or seven times and get pressure, but it slowly fades out. Someone please explain to me what i am doing wrong or what is happening? Thanks.
Feb 1, 2017 at 8:32 AM
HMAC300
  • 48,601 POSTS
if the vehicle has an ABS system you have air in the ABS part and will need a scanner to open the ABS valves and bleed the system that way. it takes a specialized scanner that most pros have.
Feb 1, 2017 at 9:33 AM
CHRISTIAN GETZ
I will try that next and let you know. Thank you!
Feb 1, 2017 at 9:35 AM
CJ MEDEVAC
  • 11,004 POSTS
HMAC 300 might have the right answer.
I'm just giving you another possibility.
Could be your bleeding technique?
Before you spend $$$ look over the way I bleed the master cylinder and the brakes.
See my link,
https://www.2carpros.com/questions/1998-ford-f-150-cant-get-brakes-bleed
Return with good news!
The Medic
Feb 1, 2017 at 6:02 PM
