Just had new brakes n rotors put on two days later started making loud roaring noise now no brakes at all
Apr 2, 2016 at 1:41 PM
HMAC300
CERTIFIED EXPERT
have work rechecked if it's a brake problem from work done shold be covered for free. however it may need the system bled causing your no brake problem also check fluid level in master cylinder if empty you probably have aleak someplace.
