I noticed brake fluid on ground (driver's side front). Took to mechanic he replaced 2 sections of brake line going to master cylinder. He tried for a couple of hours to bleed brakes, getting no air out, very little fluid-no pressure. Mechanic said it had to be master cylinder. he replaced it, no change in problem. He tried to bleed brakes again, same thing. Any suggestion as to what to check or look for? Any tests I could run? I'm already out over $100.00 with no brakes still yet!
Aug 8, 2019 at 9:12 AM
