I am reading this post because I am having the same issue with the same truck. 2000 F150. Four wheel disc. I am guessing four wheel ABS. One on each front wheel, one on rear end. New brake pads and new rotors. Calipers functioning fine. I bought the truck for $200.00. Needed a new fuel pump. Upon test drive I blew a brake line that runs inside left frame rail near back of fuel tank. I was only quarter of a mile from house. Dropped tank and repaired brake line. Today is the tenth time I have bled the system. I did replace master cylinder because of same pedal issues. Bench bled and bled on truck. Have not tried bleeding lines. Gong to try that tonight after it cools down a bit.
May 28, 2018 at 5:34 AM
