I put new seals on front calipers but in the process of waiting on parts the clamp pinching right brake hose came off and master cylinder ran empty. With it put back together I vacuum bled the front but couldn't get a pedal, so I bled the rears. Still no pedal so I started engine, pumped brake pedal and finally got a pedal with engine off only so I plugged in Xtool scanner and tried to bleed ABS but when I selected icon it says unsupported. What next, continue bleeding brakes? The brakes worked fine before other than one seized piston on each side which I fixed. I submitted this question over the weekend, but I didn't recall anywhere that asked for email. Thanks in advance!
May 10, 2022 at 4:34 PM
