Nope. I have not used a bleeder ball since the 1980's. I only do gravity-bleeding, particularly because I am usually doing that by myself. Also, it is real easy to damage a master cylinder by pushing the brake pedal more than half way to the floor, and I do not trust helpers to avoid doing that.
In this case you are usually instructed by the scanner to press a button on it, then to push the brake pedal. That initiates a sequence where the pump runs and it opens two "apply" valves. That purges the air from those two chambers and runs enough brake fluid to get any air to the bleeder screws. No pedal pumping required.
Jun 15, 2018 at 6:53 PM
