So you had 12 volts on the upstream side of the plug with it unplugged, correct?
And you have 0 volts at the socket with it plugged in?
And you are testing the brown wire for all of these as that is the brake light wire?
We are either losing info in the translation or something is missing because if the above info is correct the only possibility is a bad connection between that plug and the socket which is causing a voltage drop but all the info isn't adding up. It is in fact conflicting.
So here is what I need to help you.
Taking all these measurements can get hard to remember all the results, so I will itemize the tests I need you to do by number and description. Print this post out then take it to the car and write the results down for each number. Then come back and simply type just the number of the test and the result and I will compare that to this post.
1: Voltage reading on the upstream side of the plug.
2: Voltage reading on the down stream side of the plug.
3: Voltage reading from the upstream side of the plug to the socket.
4: Ohm reading from one side of the plug to the other side.
5: Ohm reading from the upstream side of the plug to the socket.
All of these tests should be done on the brown wire.
Rich
Sep 20, 2019 at 10:43 PM
