Pressed hazard button and stereo died?
2001 KIA RIO
128,709 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
CRAZYCOLLETTI
  • 4 POSTS
Was dropping off a friend today and because there wasn’t an actual spot to park I just pulled over and pressed my hazard button and instantly my stereo died as well as the hazards did not come on and when my friend got out he informed me that I also did not have brakes lights. No my turn signals and tail lights both work but not the hazards brakes or stereo. I checked all the fuses and none of them were blown so now I’m at a loss. Anything you can do to help me would be greatly appreciated. Thank you and have a great evening
Nov 20, 2025 at 5:35 PM
AL514
  • 5,465 POSTS
Hello, I know you didnt find any blown fuses, but Id go back over them, checking with a test light on both tabs of each fuse. You can see how the Hazards, Turn signals and Radio are tied together to certain fuses such as the Memory Room Fuse or BTN Fuse. Checking with the Key On, engine off, and then engine running, using a test light will help ensure you didnt miss any fuses. It sounds like you may have a wire on the turn signal/Hazard circuit thats shorted to ground, and didnt pop the fuse until the Hazards were turned on. I will post further info here as well.
Nov 21, 2025 at 10:50 AM
AL514
  • 5,465 POSTS
If these diagrams do not post correctly here, I can send them via email. We are having some technical work done and some imagines of wiring diagrams are not being displayed on the posts in some cases.
Nov 21, 2025 at 10:53 AM
AL514
  • 5,465 POSTS
I will just need an email address to send these too.
Nov 21, 2025 at 10:56 AM
CRAZYCOLLETTI
  • 4 POSTS
[email protected]
Nov 21, 2025 at 10:59 AM
CRAZYCOLLETTI
  • 4 POSTS
And it’s all lowercase
AL514
  • 5,465 POSTS
Ok give me just a couple minutes and Ill get them together and send them over. If you need anything in addition to these just let me know. You can post you questions here because I will get a notification for it.
Nov 21, 2025 at 11:04 AM
AL514
  • 5,465 POSTS
Theres a period after the first name in the email address?
Nov 21, 2025 at 11:05 AM
CRAZYCOLLETTI
  • 4 POSTS
Yes there is a period between my last and first name
Nov 21, 2025 at 11:08 AM
AL514
  • 5,465 POSTS
Ok I sent the Turn/Hazard(exterior lighting Power Distribution diagrams) and the Radio. If you need any other info, just ask here.
Nov 21, 2025 at 11:16 AM
AL514
  • 5,465 POSTS
Glad you got those ok, and stay warm out there.
Nov 21, 2025 at 11:39 AM
