That would be the whole stick assembly that you lift up and down for the turn signals,
Yours is inside the column on your modern Jeep, Sort of like things did not change much since 1976 (Mine is a 1977. Back then it was just called a turn signal switch and its only other function was hazards!)
See my link.
https://shop.advanceautoparts.com/p/driveworks-multi-function-column-switch-55239/10703874-P?searchTerm=multi-function+switch
Before you get too crazy.
Check all of your fuses, Actually pull 'em out and reinstall them. Being a Jeep, it is probably been subjected to the elements. Corrosion may be in the fuse connections.
The Medic
Jul 29, 2017 at 6:03 PM
