The transmission range sensor is what determines the gear selection and signals the backup lights to turn on. It is located in the transmission (valve body).
When you shift through the gears, is the gear indicator correct?
If you look at the first two pics below, I included the entire wiring schematic related to the backup lights. If you haven't already, check to see if there is power to the lights. If there is, you could have a ground issue. Make sure you check the relay as well. Here is a link to help:
Next, there was a recall related to the backup lights on several F-150's and Expeditions. I swear it included 2011. I attached the original recall (pics 3 and 4). You may want to contact a dealer, provide the VIN number, and see if this vehicle falls under the recall.
See pics below.
May 3, 2021 at 7:51 PM
