No AC/heat no power to AC/heat controls
2010 NISSAN MURANO
152,000 MILES • 4 CYL • 2WD • AUTOMATIC
KEITH_P
I have no A/C or heat. The buttons on the panel to control them don't work and when pressed there is no light showing they are on and off. The radio and GPS/navigation works just fine. I have replaced the blower motor, and the ac auto amp and still nothing. Ran the diagnostic test and the TX for HVAC was okay but the Rx for HVAC came back unknown. Replaced multiple fuses as well.
Oct 28, 2020 at 9:32 AM
Are there any trouble codes that are present? For example, is U1000 or U1010 present? If not, then we need to move to a test. Here are the directions. Starting at number 3, it focuses on the HVAC RX circuit continuity. I have a feeling this will lead you to the fault.
The attached pics correlate with the directions.
________________________________________
2010 Nissan-Datsun Truck Murano FWD V6-3.5L (VQ35DE)
Without 7 Inch Display
Vehicle Heating and Air Conditioning Testing and Inspection Component Tests and General Diagnostics Automatic Air Conditioner A/C Control Signal Circuit Without 7 Inch Display
WITHOUT 7 INCH DISPLAY
A/C CONTROL SIGNAL CIRCUIT
Diagnosis Procedure
1.CHECK WITH SELF-DIAGNOSIS FUNCTION OF CONSULT-III
1. Using CONSULT-III, perform "SELF-DIAGNOSIS RESULTS" of HVAC.
2. Check if any DTC No. is displayed in the self-diagnosis results.
NOTE:
If DTC is displayed along with DTC U1000 or U1010, first diagnose the DTC U1000 or U1010. See: A L L Diagnostic Trouble Codes ( DTC ) > U Code Charts > Without 7 Inch Display or See: A L L Diagnostic Trouble Codes ( DTC ) > U Code Charts > Without 7 Inch Display.
Is any DTC No. displayed?
YES - Perform the diagnosis that is applicable to the sensor and actuator. See: A L L Diagnostic Trouble Codes ( DTC ) > Testing and Inspection.
NO - GO TO 2.
2.CHECK TX (A/C CONTROL to A/C AUTO AMP.) CIRCUIT CONTINUITY
1. Disconnect the A/C control and the A/C auto amp. connector.
2. Check continuity between A/C control harness connector and A/C auto amp. harness connector.
pic 1
3. Check continuity between A/C control harness connector and ground.
pic 2
Is the inspection result normal?
YES - GO TO 3.
NO - Repair harness or connector.
3.CHECK RX (A/C AUTO AMP. to A/C CONTROL) CIRCUIT CONTINUITY
pic 3
pic 4
YES - Perform trouble diagnosis for the A/C control. See: Heating and Air Conditioning > Component Tests and General Diagnostics > A/C Control.
_________________
Let me know what you find.
Oct 28, 2020 at 8:15 PM
KEITH_P
I pull up the diagnostic on the in dash screen and it won't let me select the HVAC option. It's there, however, I click on it nothing happens. I did run the CAN system test and got this. see pic below.
Possible relay? The panel itself? I read it could be the IPDM. Really at a stand still and the cold weather is coming in.
Oct 31, 2020 at 8:04 PM
Based on what I'm seeing, it sounds like a wiring issue. If you look at the directions I attached above, go down to number 3. Is that something you feel comfortable doing?
Oct 31, 2020 at 9:25 PM
