No AC
1997 SATURN SW1
150,000 MILES • 1.8L • 4 CYL • FWD • AUTOMATIC
ROBERT1468
AC Compressor housing at 220 degrees on a 75 degree day. Both high and low lines very hot, but cool at pressure switch. I have 2 gauges, one says 25 psi and the other says 40 psi. I get no cold at all. Compressor is running constantly.
Feb 9, 2016 at 1:58 PM
WRENCHTECH
  • 20,761 POSTS
Those pressures make no sense. Diagnosing AC issues requires a lot of experience and observations. It's definitely not a DIY job. There are way too may things to go wrong and way too many things that have to be observed and analyzed. The very first step is a complete evacuation and recharge. It's the only way to know exactly how much refrigerant is in the system. The pressures don't mean anything until you have the exact correct charge.
Feb 9, 2016 at 4:36 PM
ROBERT1468
Thanks for the response:
The pressures that I gave you are only the low pressure side, the gauges just don't agree what it is. The 40 psi is a true reading. If the expandtion valve is stuck closed, or can the dryer plug-up and be the cause.
Feb 9, 2016 at 6:39 PM
WRENCHTECH
  • 20,761 POSTS
As I said, the pressures don't mean a thing until you have the exact weight charge and then just having the low only reading won't tell you anything.
Feb 9, 2016 at 6:46 PM
ROBERT1468
Okay, Thanks
Feb 9, 2016 at 6:48 PM
What is the high side reading?
Feb 10, 2016 at 7:51 AM
WRENCHTECH
  • 20,761 POSTS
He doesn't have one Ken.
Feb 10, 2016 at 8:10 AM
