The AC started only blowing cold intermittently a couple of days ago. I hooked my gauge to it and it said it was "low."
Today I hooked the gauge to it and more closely saw that when the compressor kicks on, the pressure gets too low and then it kicks off. So, I hooked it up to my AC machine.
Here is what happened:
- The machine held a vacuum at 30mmHg for about thirty minutes.
- It recovered 2.12 lbs (the car holds 1.87 lbs).
- It charged the system with 1.87lbs.
However, it failed the leak test.
How can it be possible to fail a leak test, stay at 30mmHg, and hold the charge pressure?
Now, problem is still that it will not blow cold. In fact, the fans will not even turn on now, even for heat. I am at a loss with the gauges reading good pressures and there is no air.
Aug 14, 2018 at 11:29 AM
