The A/C went out. I have codes P0010, P0013, P0032, P0645, P2008. I erased codes and all came back except P2008. I went to ground G110. as it said on u-tube. All black with white strip were good. I put 12V to the power line to the compressor. I heard a click, and everything came on. The check engine light went out. Worked all day. That night it was back on. I went back to G110 and found a black with purple strip wire with no ground. Repaired that but it didn't fix anything. I went back to the compressor but the 12V didn't work. I pulled the connector to the compressor and had 5 volts to each wire. Checked and cleaned all grounds. Still nothing. On the wiring diagram it has the ground to the compressor solenoid as G904. I don't know where that is. I have continuity between the 2 wires to the compressor. When I pull the PCM's C2 plug I have nothing, so I am thinking PCM. There is a connector on the side of the fuse box with a heavy black with white strip. It is ground until I start the car, then voltage, but only 5 to 9 volts.
Any idea's
Any idea's
Jun 28, 2023 at 2:06 AM
