No A/C
2003 KIA SEDONA
132,330 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
I have checked all relays and compressor and hi and low
cut outs. I have power into A/C control head at pin 1r.
I just need to know what pin is output at the control head? Also,
the lights come on when A/C button is pushed as does the recirculate.
Jun 26, 2018 at 6:41 PM
Good morning.
I attached wiring diagrams for you to view of the control head.
Did you verify voltages to the pressure switches?
https://www.2carpros.com/articles/car-air-conditioner-not-working-or-is-weak
Jun 27, 2018 at 4:52 AM
Howdy the answer is great, thank you. However, the schematic is blurry and we use
Prodemand as our diagnostics believe if I can find out what pin connector is the output
I can tell if it is the control head or PCM. Note: even the scanner does not show a/c on when
button pushed but light comes on on dash.
Jun 27, 2018 at 11:33 AM
Pin 6 on the control head. I highlighted it in yellow.
That is for the control side of the AC clutch relay.
Jun 27, 2018 at 12:37 PM
