Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
Ion
General
Noises
Grind
No fifth gear
2005 SATURN ION
183,000 MILES • 2.2L • 4 CYL • FWD • MANUAL
NICKDIONNE2008
MEMBER
FOLLOW
First through fourth shift fine, but it will not go into fifth it just grinds. any idea what it could be? linkage?
Jun 26, 2017 at 12:31 AM
SATURNTECH9
CERTIFIED EXPERT
If you turn the car off will it go into the gear it grinds into with it running?
Jun 27, 2017 at 11:12 AM
SATURNTECH9
CERTIFIED EXPERT
If someone is watching at the transmission while your shifting is the cable and linkage moving?
Jun 27, 2017 at 11:13 AM
NICKDIONNE2008
MEMBER
Yes linkage is moving and when car is off it seems like it goes into 5th
Jun 27, 2017 at 6:01 PM
SATURNTECH9
CERTIFIED EXPERT
Then most likely you have a bad 5th gear synchro blocker ring.Thats what let's the gears change without grinding.
Jun 27, 2017 at 6:27 PM
SATURNTECH9
CERTIFIED EXPERT
I have had a few of those transmissions apart that were grinding into only certain gears and that's what is was.
Jun 27, 2017 at 6:28 PM
