No fifth gear
2005 SATURN ION
183,000 MILES • 2.2L • 4 CYL • FWD • MANUAL
NICKDIONNE2008
First through fourth shift fine, but it will not go into fifth it just grinds. any idea what it could be? linkage?
Jun 26, 2017 at 12:31 AM
SATURNTECH9
  • 30,869 POSTS
If you turn the car off will it go into the gear it grinds into with it running?
Jun 27, 2017 at 11:12 AM
SATURNTECH9
  • 30,869 POSTS
If someone is watching at the transmission while your shifting is the cable and linkage moving?
Jun 27, 2017 at 11:13 AM
NICKDIONNE2008
Yes linkage is moving and when car is off it seems like it goes into 5th
Jun 27, 2017 at 6:01 PM
SATURNTECH9
  • 30,869 POSTS
Then most likely you have a bad 5th gear synchro blocker ring.Thats what let's the gears change without grinding.
Jun 27, 2017 at 6:27 PM
SATURNTECH9
  • 30,869 POSTS
I have had a few of those transmissions apart that were grinding into only certain gears and that's what is was.
Jun 27, 2017 at 6:28 PM
