Crank, no start. Replaced crankshaft sensor, camshaft sensor, ignition switch, and PCM. Checked all three wires from PCM to end of crankshaft sensor connector for continuity and all are good. I have "peeled" back some insulation from twelve volt green wire coming immediately out of PCM and can use a jumper wire from hot post of battery to the wire and it will immediately start. Any ideas what is going on? Thanks in advance for any help.
Jan 9, 2018 at 4:39 PM
