My number 1 20A fuse for the stop/TCC/hazard blows immediately when I press my brake pedal. Since I have discovered this problem I have done the following to isolate the issue with no luck:
- Disconnected all tail lamps (at the rear harness split).
- Visual inspection of all wires (pulled steering column cover and dash panel to get better observation).
- Replaced brake light switch.
- Disconnected the TCC plug.
No matter what I try, as soon as I touch the brake pedal, the number one 20A fuse blows causing my brake lights and hazards to not work.
All other lights and electronic features are working fine.
At this point I am considering that the problem might be in the "combination switch". Does this seem correct? Do you have any other ideas? Is there a way to test my hypothesis before I go make the purchase and go through the effort?
I have read a few threads on a similar issue but they do not seem to describe the exact same problem.
Thanks,
Jared
Thanks,
Jared
Jun 25, 2018 at 9:02 AM
