shudders and a bang when shifting at speeds over forty mph and drops into limp mode
2008 DODGE NITRO
77,000 MILES • 2.8L • 4WD • AUTOMATIC
LYN BURNS
  • 4 POSTS
The vehicle will drive like a dream for a few days but always shudders when you stay around forty mph. I get a bang going up the gears past 40 mph and then acceleration goes or it goes into limp home mode. I have to pull over park and turn off engine to clear it. What do I need to do to get it fixed? Who can fix it?
I will look at transmission levels but not long had a service prior to me buying.
I have no skills just a female driver.
Thanks in advance.
Feb 8, 2017 at 10:32 AM
HMAC300
  • 48,601 POSTS
check with a dealer on this as there is TSB that is calling out a shudder from torque converter and needs to be reprogrammed. there should not be a charge for this, but check anyhow. the number is 18-027-08.
Feb 8, 2017 at 12:30 PM
LYN BURNS
  • 4 POSTS
Thank you, however I am in the U.K. What is a TSB?
Feb 8, 2017 at 2:54 PM
HMAC300
  • 48,601 POSTS
technical service bulletin. However, it may only apply in the US. so check with dealer as it may be the same but a different number.
Feb 8, 2017 at 3:44 PM
CARADIODOC
  • 34,306 POSTS
Sorry for butting in, but I have a comment of value to add. If that service you mentioned was for the transmission, a real good suspect is they used the wrong transmission fluid. The clue is your dandy observation that the shudder occurs near thirty to forty mph. That is exactly where the torque converter locks up to provide improved fuel economy. There are two things you can do to verify this. The first is when the shuddering is occurring, hold the accelerator pedal perfectly steady, then with your other foot, lightly tap the brake pedal for an instant. That will cause the torque converter to unlock for two or three seconds, and engine speed will increase about 200 rpm. The other thing is to observe the shudder does not occur at forty mph when the engine is still cold. If you start a cold engine that has been sitting overnight, then get out on the road right away, the torque converter will not lock up for the first five to ten minutes, so no shudder will occur.
"TSB" is "technical service bulletin". Those are quite different than recalls. Service bulletins are issued to identify the causes and fixes for problems that have been identified as common, but have elusive solutions. They are intended to reduce the need for each mechanic to spend a lot of time searching for the same thing.
The service bulletin HMAC300 found involves the air conditioning compressor cycling on. If this is related, the shudder may not occur when you have the AC turned off, and the heater is not in "defrost" mode. The AC system runs when defrost mode is selected.
Feb 8, 2017 at 3:54 PM
LYN BURNS
  • 4 POSTS
Thank you, I shall try this out today. what transmission fluid should be used? I will check the invoice off the last service.
Feb 9, 2017 at 3:11 AM
HMAC300
  • 48,601 POSTS
part of the problem is you have a 2.8L which I am suspecting is a diesel so it may be different from US spec. However, the US spec is automatic transmission fluid Plus 4 or equivalent. If you have a manual for this then check in there as it will say in there as well.
Feb 9, 2017 at 6:52 AM
LYN BURNS
  • 4 POSTS
Just been to Jeep garage and they hooked the Nitro up for health check. Found a gearbox leak due to no adapter present. Quoting me £145 for hour labour and adaptor. The Nitro has driven well since they topped her up with ATF. Is this a good price?
Feb 20, 2017 at 5:03 AM
HMAC300
  • 48,601 POSTS
we don't know prices in the UK doesn't sound bad though as I know prices there are much higher than in US
Feb 20, 2017 at 2:06 PM
