2007 Nissan Xterra stereo
2007 NISSAN XTERRA
30,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHREEFER71
how do i remove the stereo from the dash ?
Nov 18, 2009 at 8:45 PM
KHLOW2008
  • 41,814 POSTS
Hi shreefer71, Thank you for the donation. Here are the procedures. CLUSTER LID C Removal CAUTION:Before servicing, turn the ignition switch off, disconnect both battery cables and wait at least 3 minutes. 1. Disconnect battery negative terminal. 2. Disconnect battery positive terminal. 3. Pull cluster lid C rearward to release clips. 4. Disconnect electrical connectors and remove cluster lid C.
https://www.2carpros.com/forum/automotive_pictures/192750_Radio07XterraFig05_1.jpg
Installation Installation is in the reverse order of removal. AUDIO UNIT 1. Remove the audio unit screws. 2. Pull out audio unit, then disconnect connectors.
https://www.2carpros.com/forum/automotive_pictures/192750_Radio07XterraFig47_1.jpg
Nov 19, 2009 at 11:53 AM
