okay so im driving down the road and the car's RPM'S drop to 0, the steerig jogs for a few seconds and had no gas peddle response. once i slowed it down and got pulled into the parking lot it then sputtered a few times and died. I got it home and checked the timing belt, its fine. checked the gear on the distributor and its fine. got everything put back together, then checked and realized i had no spark.. coming from the plug when you pull it and put a plug in, NO SPARK. pull the distributor cap, The rotor isnt turning when the distributor is in the engine but it turns out of the engine..... i need help please... what can i change/ check and test?????
Jan 11, 2010 at 9:28 AM
