2001 Nissan Xterra Passenger Side Window will not work.
2001 NISSAN XTERRA
12,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARK.G.DAVIS
My window quit working, in fact in slightly fell down and will not roll up or down. When I attempt to roll it up using the switch I hear no noice. When it first happened the window was stuck half way and it took a little effort to push it up so that it would close. I had to prop it up. I'm in the UK and will be traveling back to the states so I thought I'd pick-up the parts. What is your best guess based on this account that I should get to be on the save side.
As a side note the window showed no signs of trouble before this occured.
thanks
Sep 29, 2009 at 2:29 AM
MERLIN2021
  • 17,250 POSTS
You need to remove the trim panel to access the motor/regulator, unplug the motor, test the harness with voltmeter or test light. if there is power, you need a new motor, if no power, the switch or relays are bad. Or maybe a broken wire in the conduit that runs from the door to the inside of the cab. Where they bend, the do break!
Sep 29, 2009 at 2:14 PM
