[quote:90f6a3285b="quizatz"]Engine Performance problem
2000 Nissan Xterra 6 cyl Two Wheel Drive Automatic 65000 miles
Yesterday Merlin 2021 answered a question at 3:32 edt. Still have the problem and suspect fuel quality.
Car starts and idles fine, as soon as 1500+ RPM is hit it sputters and stalls. After 24 hrs sitting started up and went to 4000 rpm and held with no problem if it were exhaust obstruction this would not have happened would it? Put in 17 gals of high end fuel and the problem is back! I'm thinking water went to top of tank fuel, car ran fine, then new fuel in mixed all up and now impurities are causing problem again. So, do you think I'm right that it must be fuel? If so how can I SAFELY remove aprox 18 gallons from a tank with a syhon defense in the filler neck?
I need response by Mon noon.[/quote:90f6a3285b]
Sometimes a clogged exhaust can vary in the circumstances.
To remove the fuel you can either use the fuel pump to pump it out (remove fuel hose from fuel rail and attach a hose to a collecting tank, loop the fuel pump relay to get it running with ignition switch on)
Or drain it from the fuel tank via the drain plug (some models are not equipped with drain plugs)
If engine is equipped with EGR system I would suggest disconnecting the EGR valve vacumn hose to test.
Sep 15, 2008 at 7:01 AM
