One of my windshield wiper does not work
1993 NISSAN XTERRA
U863999
Six cylinder four wheel drive automatic 41,000 miles
One of my windshield wiper does not work. the driver side wiper works but the passenger side does not work. We had a lot of ice and snow lately.
Does each wiper have a separate motor?
could it be a fuse?
Mar 6, 2009 at 6:23 AM
KHLOW2008
  • 41,814 POSTS
Hi u863999,
Thank you for the donation.
The wipers uses a common motor and your problem should be a dislodged wiper link. You need to check if the link joints are worn.
Are you sure the year model is correct? I could only find Xterra for year 2000 onwards.
Mar 6, 2009 at 6:46 AM
U863999
It is a 2003.
Mar 6, 2009 at 6:55 AM
KHLOW2008
  • 41,814 POSTS
I have the diagrams showing the components.
https://www.2carpros.com/forum/automotive_pictures/192750_WiperLinks03Xterra_1.jpg
Mar 6, 2009 at 10:07 AM
KMONSEES
the windshield wipers do not work when its in an "on" position, but they do work when you use the wash function and the go for two or three turns. The car is with my kids in college so I am trying to get them an answer to fix the problem. Thanks.
Jan 11, 2017 at 12:18 PM (Merged)
ZOLTAN24
driver side windsheild wiper will not work after brushing snow off. motor works, wiper moves just a little bit.
PAMBO
Six cylinder front wheel drive automatic 124,303 miles
my windshield wipers (front) will not work. this happened after a heavy snow fell off the top roof onto them. they try to move a hair but will not perform.
Jan 11, 2017 at 12:19 PM (Merged)
SBPRES
Six cylinder four wheel drive automatic 139,000 miles
The drivers side windshield wipers do not work. Sometimes it want to move with the other wiper but does not move. You can move the windshield wiper yourself but will not move in sync with the other wiper. The passenger side wiper can not move manually.
STEVE342
Six cylinder two wheel drive automatic 120,00 miles
there is no sound coming from the pump however the wiper fluid works on the rear wiper system . it was suggested that it may be the washer pump/motor is this possible and how hard is it to change? i also was told you have to take the whole side fender apart. please help
