2010 Nissan Versa Oil lighting
2010 NISSAN VERSA
1,700 MILES • 4 CYL • AWD • AUTOMATIC
ALFUNG
I bought a new versa in May. In the past month and a half I have but quite a few miles on it (over 1700), with moving to another state. Before I moved I did go into the nissan service station because my check engine light came on (I did not put the gas cap on properly). They did a check of the car and everything was ok. Recently my oil light came on. It would come and then come off a couple minutes later. I put oil in the car but the oil light came on again. What should I do?
Jul 6, 2010 at 3:24 PM
Check the oil pressure with a mechanical gauge,if normal replace the oil pressure switch. If abnormal could mean oil pump and/or engine bearing.
Jul 6, 2010 at 6:52 PM
