Hello, hopefully you can help me. I have a 1992 nissan pickup truck, its a standard pickup, with 125,000 miles on it. It started with the head lights going out on it, the low beams dont work at all, only the high beams. The dash lights went out with the low beams, now my rear running light dont work, only my brake lights. HELP ME!!!
I have had new bulbs installed and that does not seam to be the problem, I also have had someone look at the wiring thinking that was the problem, but that doesnt seam to be the case either. I was told it could be a bad ground.
The main problem right now is getting my lights fixed, I am a women and dont know very much about vehicles and I am worried that I might be taken advantage of when they see me coming, what would you suggest?
Also, I dont know if this has anything to do with it or not but just before my lights when out the speedomiter and odomiter went out as well. I will be getting those fixed as well, but for know I need my lights done.
Any help you can provide would be great.
Thank you!
Thank you!
Mar 16, 2006 at 6:56 AM
