2007 Nissan Truck engine will not crank
2007 NISSAN TRUCK
160,000 MILES • 4 CYL • 2WD • MANUAL
MARCIA_73HN
This winter I have had problems with my car engine not cranking with the temperature outside at 0 and below. I had a tow truck show up and crank the vehicle. I changed the battery. About two weeks later I am still having problems with the vehicle intermittently not cranking. The engine will crank if I am towed or if I start on a hill. Any ideas what I could check for myself? Thank you.
Feb 5, 2009 at 9:56 PM
You can try this-Get a helper to hold key at start position while you bang on the starter if it engages the engine-replace the starter if not recheck the starter, starter relay,interlock-clutch switch and ignition switch.
Feb 5, 2009 at 10:04 PM
