2006 Nissan Truck engine miss slow starting
2006 NISSAN TRUCK
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
TALAWINE
engine miss going up hill slow starting replaced spark plugs air filter ran 2 bottles of lucas injector cleaner thru
Mar 13, 2010 at 11:19 AM
2CARPRO JACK
  • 11,533 POSTS
Has it ever set the check engine light? if so have it scanned for codes.Is uphill under load the only time is misses?Sounds like ignition if that is the case.Does it feel like you are losing 1 cylinder or does the engine feel like it is stumbling?May want to check fuel pressure if that is the case, a lean mixture can cause random misfires, plus that could explain the slow starting
Mar 16, 2010 at 8:30 AM
