Dear Car Pros,
My engine starts up fine but the idle is very rough and the engine stalls.No 'Check Engine Light' is present at any time. I need to feather or depress the gas pedal to keep it from stalling.If I get the engine to somewhat warm up then it idles(very rough) for 6-10 minutes. When it's cold maybe 2 minutes.The tach shows rpm's on the high end 1800-2k and the low end 500 and below. All avenues lead me to the IACV-AAC valve but have tested it with battery clips and wires to test the solenoid with the AAC attached to it and the solenoid SEEMS to work as I can see the plunger moving in and out as I energize the solenoid.I have cleaned the AAC air passages and throat of the throttle body and MAYBE has helped alittle.I have a Nissan Factory repair cd in pdf and has helped tremendously. But cannot find the problem due to the erratic idle. I can't just throw parts at it as an IACV-AAC is 165 clams from the dealer. Can you help? Thank You!
Feb 11, 2009 at 7:35 PM
