1997 Nissan Truck Rev Limiter
1997 NISSAN TRUCK
119,000 MILES • 4 CYL • 2WD • MANUAL
BAFFLED123
I have a 1997 nissan xe hardbody D21 pickup. Engine runs great up to 2000 RPMs then it acts like the rev limiter kicks in. What could be my problem?
Jun 6, 2010 at 3:22 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 7, 2010 at 2:53 AM
