1997 Nissan Truck large vacuum leak
1997 NISSAN TRUCK
18,073 MILES • 4 CYL • 4WD • MANUAL
GUSWHEEZ
Recently my check engine light came on. A few days later the ABS light came on, then shut off. (the ABS has come on and off a couple of times), then my cruise control light started blinking and quit working, then my A/C yesterday stopped blowing cool air. The light is not coming on for the A/C
I took it in for a diagnostic check
It is saying either "blocked injector", large vacuum leak or MAF sensor fault
My question is: could all these symptoms be related due to a vacuum leak or sensor fault???
May 12, 2009 at 10:53 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Can you post the actual codes that were set? this will help me determine the exact cause of your problem.
Mark (mhpautos)
May 13, 2009 at 12:32 AM
GUSWHEEZ
Thanks for your prompt replie.
There was only one code that was set when they ran the diagnostic.
OEM number P0171
May 13, 2009 at 1:30 AM
