no reverse and no 5th gear
1996 NISSAN TRUCK
110,000 MILES • 4 CYL • 2WD • MANUAL
RICHDRE
I have a manual trans where the reverse went out and then the 5th gear is not engaging. thanks for your help.
rich
May 7, 2010 at 7:23 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
5th & reverse are on the same selector rod, does it feel like it is selecting but no drive or is it just sloppy and not selecting?
Mark (mhpautos)
May 7, 2010 at 7:27 PM
RICHDRE
The 5th gear feels like there isn't anything there no engaging. The reverse will not engage, like the gear is blocked or closed.
thanks for your time
rich
May 8, 2010 at 2:09 PM
MHPAUTOS
  • 31,937 POSTS
The transmission is broken internally here is a link to help you remove it.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
May 8, 2010 at 8:01 PM
RICHDRE
thanks again
rich
May 9, 2010 at 12:52 AM
CASEYLMAN
Lost reverse over a period of 4 days. Sometimes went right in to gear and then slow to engage and now completely lost reverse. When Shift lever goes to reverse you can hear a faint hissing noise fom underneath , stops when moved to park or neutral , have found a small vacume hose that had popped of and reconnected that helped it engage for one day then completely lost reverse. Fluid is at proper level and clean with no burn odor , never had a problem with trans , purchased new in 95 .
Could the filter be clogged or some simple common problem ?
Thanks
Sep 10, 2019 at 4:43 PM (Merged)
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated You need to have a transmission shop look at the vehicle .. and check for any transmission fault codes stored .. Vehicle Will Not Move In "R"; Okay In "D", "2" & "1" Incorrect control linkage adjustment or line pressure. Damaged control valve assembly, line pressure solenoid valve, reverse clutch, high clutch, forward clutch, overrun clutch or low and reverse brake. Hope this helps
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_785.png
NISMOMAN13
ok heres my question i have and 88 nissan pickup 2.4 nap-z 4x4 5 speed with approx 193000 on the odo, when i put my truck in reverse and disengage the clutch it kicks out of reverse but not before it grinds and like it sounds like the gear it not meshing or something it doesnt do it in any other gear though other than that it doesnt have any problems but i t wont let me back up or very little i dont know what to do to fix it i am very mechanically inclined but it finding the time to do it which is why i would rather know what im looking at to fix any help would be great thanks matt
https://www.2carpros.com/forum/automotive_pictures/77461_dscf1568_1.jpg
KAMO
  • 47 POSTS
Check your fluid, chance are that isnt the problem but, one possibility is your slave cylander is leaking. Another cause is a bad clutch. Check for the leak first, then Id say do a, or have some one do a clutch inspection.
