1995 Nissan Truck dies
1995 NISSAN TRUCK
200,000 MILES • 4 CYL • 2WD • MANUAL
MARKRANDI
whether on the freeway or at a light truck dies. on the freeway tach & speedo drop (elect failure). turn h/l's on & everything starts working. samething at a red lt. at a red lt. truck stalls. sometimes starts rt. away sometimes not. turn h/l's on & it will start.
please answer to personal email:
Dec 26, 2008 at 8:27 AM
Inspect and test the IACV-ACC and the TPS also the PCV and EGR valves, to include checking the exhaust for restriction
Dec 27, 2008 at 7:18 AM
MARKRANDI
[quote:c6c2ef8c77="rasmataz"]Inspect and test the IACV-ACC and the TPS also the PCV and EGR valves, to include checking the exhaust for restriction[/quote:c6c2ef8c77]
Would these items cause a complete loss of electrical power? Backpressure is good-EGR is new. PCV is functioning properly. What's making the truck die is a complete loss of electrical power-wipers, lights, radio, heater/ac. Could be going down the freeway or sitting at a red lt. Battery load tests good & alt. is putting out 13.5 v. I was wondering about the regulator because at night, 1 time, I noticed the dash lts. get brighter by themselves.
Dec 28, 2008 at 3:59 PM
You could be right on the voltage regulator-full field the alternator meaning bypassing the regulator if it increases more than 13.5 volts then its not working right-replace it-
Dec 29, 2008 at 3:29 PM
