1995 Nissan Truck A/C Not working
1995 NISSAN TRUCK
15,000 MILES • 4 CYL • 2WD • MANUAL
ALLENMINTON
When I crank my truck, it makes a squeaking sound (like a belt) It only does this when the A/C is on.
and will continue to squeak at high RPM's.
Then the A/C will start blowing hot air. Then it will make the squeaking sound (just for a minute) then the air will blow cold again. is this a sign of the compressor going out?
Thanks,
Allen
Jul 10, 2008 at 7:04 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d555c77b3d="allenminton"]Air Conditioning problem
1995 Nissan Truck 4 cyl Two Wheel Drive Manual 150,00 miles
Thanks,
Allen[/quote:d555c77b3d]
When was the last time you have the A/C System Services? Is the system fully charged? It could just be the Clutch in combo with low freon. If the system is charged then it may be the Compressor.
To check if clutch is noisy before starting spray the a/c pulley in the center to lube the bearings. start vehicle if noise is gone then clutch bearing are going bad.
Jul 10, 2008 at 7:31 PM
