Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Nissan
Truck
Exterior Light
Turn Signal
Fuse
1994 Nissan Truck Tail lights, signal lights
1994 NISSAN TRUCK
164,000 MILES • 4 CYL • 2WD • MANUAL
MRANDWHATSO
MEMBER
1 POST
FOLLOW
The tail lights nor the signal lights are working, I checked the fuses and each individual light bulb, they are all good. What should I check next.
Apr 1, 2010 at 11:04 AM
TWOSTEPPER
MEMBER
I'd check voltage and ground at the bulb socket. Did you use a voltage tester on the applicable fuse circuits?
Apr 1, 2010 at 11:42 AM
