1994 Nissan Truck gears
1994 NISSAN TRUCK
80,000 MILES • 4 CYL • 2WD • MANUAL
WEZOVER
Hi, when engine is running and clutch is pushed in, it won't go into any gear. When the engine is off, you can change the gears, no problem.
it's the XE extended cab
Jul 23, 2010 at 10:58 AM
DOCFIXIT
  • 18,828 POSTS
Got two things clutch disc worn allowing input shaft to turn or pilot bearing siezed to input shaft
Jul 23, 2010 at 3:33 PM
WEZOVER
Thanks I really appreciate it, Wes Dial
Jul 23, 2010 at 6:13 PM
