1993 Nissan Truck brake lights on...abs llight on
1993 NISSAN TRUCK
10,900 MILES • 4 CYL • 4WD • MANUAL
TATKONA
After turning off my engine and parking, I noticed that my brake/tail lights were still on...couldn't get them off....driving home I noticed that the abs light was on, too....
I had to disconnect the ground wire to the battery to get light off...fuses seemed okay....
What is wrong and what should I do to fix??
Terry
Jun 30, 2008 at 7:56 PM
KHLOW2008
  • 41,814 POSTS
Hi Terry,
Check the brake pedal switch and contact. There should be a rubber stopper, if it is worn or missing, replacing 1 would solve the problem.
If the switch pin is closing and the lights are not going off, the switch is faulty.
Jul 18, 2008 at 12:35 PM
