There is a high pitch squeal from the engine. Is this from one of the belts? And does this means it needs replacing, adjustment or both?
Apr 2, 2009 at 9:36 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Most often the squel is actually from one of the pulleys being drive by the belt, not the belt itself. You will need to listen carefully with a mechanis stethoscope or similar tool to see which, if any, pulley component needs replaced/rebuilt.
