1992 Nissan Truck Will not start
1992 NISSAN TRUCK
285,000 MILES • 4 CYL • 2WD • MANUAL
SHANAG
Ok I have a 1992 manual nissan truck. It will not start and the only to get it started is to push start it. I took off the starter and had it tested they said it was good. I had the battery tested also and it was good. What could be the issue?
Thanks
Sep 29, 2008 at 7:05 PM
Jumper the clutch switch and see what happens
Sep 29, 2008 at 7:09 PM
SHANAG
Rasmataz,
Thank you for replying. We did try that yesterday and that didn't work. Could the solenoid be bad?
Oct 1, 2008 at 8:49 PM
Check for power at the starter solenoid when key at run position -power there-replace the starter-not there-test the ignition switch
Oct 2, 2008 at 9:49 AM
