What could cause my truck not to turn over? Never had a problem before, stick shift, 249,000 miles,the battery is okay. I had the starter check it was,okay. Change the starter relay, the ignition one and two relay. When I turn the key on fuel pump kick in all electric works horn work, but nothing when I turn the key. If I push or pull and pop my clutch it will start just fine and the motor will run just fine. 2.4L, stick shift. Please help. Thanks
Aug 3, 2018 at 5:44 PM
(Merged)
