Engine Performance problem
1989 Nissan Truck 4 cyl Two Wheel Drive Manual
so i posted about an 89 nissan d21 2wd 2.4L... it still is not getting fuel to the inside of the throttle body... and the fuel pressure regulator is new and everything is plugged in... the injector is pulsating. and there is pressure in the fuel line. and when i try to give it a little gas when starting the injector makes a sound. the injector has 1.5 ohms as spec. what else could it be?
Apr 8, 2010 at 10:03 PM
