1988 Nissan Truck headlight switch
1988 NISSAN TRUCK
217,000 MILES • 4 CYL • 2WD • MANUAL
HUIEDENNIS
  • 5 POSTS
how do I replace the headlight switch?
Aug 28, 2010 at 9:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Pry out the horn pad and remove the steering wheel (explained below).
Remove the terminals from the connector.
Slide the switch assembly off the steering column.
To install:
Install the switch on the steering column and connect the electrical leads.
Press the steering wheel (explained below) onto the column and install the horn pad.
STEERING WHEEL REMOVAL & INSTALLATION
Position the wheels in the straight ahead position.
Remove the horn pad by unscrewing the two screws from the rear side of the steering wheel crossbar.
Punchmark the top of the steering column shaft and the steering wheel flange.
Remove the attaching nut and remove the steering wheel with a puller.
CAUTION
Do not strike the shaft with a hammer, which may cause the column to collapse.
To install:
Install the steering wheel so that the punchmarks are aligned. Tighten the steering wheel attaching nut to 51-54 ft. lbs. for 1970-79 models; 29-36 ft. lbs. (39-49 Nm) on 1980-86 models (720D series); and 22-29 ft. lbs. (29-39 Nm) on 1986-88 models (D21D series).
Install the horn pad.
Aug 28, 2010 at 11:42 AM
