1987 Nissan Truck throttle body
1987 NISSAN TRUCK
40 MILES • 4 CYL • 2WD • MANUAL
KADFAA
I just changed my motor in my truck. its a nissan d-21 pickup with a z 24 4cylinder. i put a new crate motor in it. i believe that something is wrong with the throttle body on it. you start the truck and on the left side of the throttle body its just shooting gas in it and the gas is coming back out to. if you push the gas pedal it just cuts off. i dont really know whats causing it to do that...
Apr 19, 2008 at 1:20 PM
Could be a problem with the injector check its resistance and also perform a fuel pressure check should read 36 psi.
Apr 19, 2008 at 4:50 PM
