1985 Nissan 720 pickup 4cyl 8plugs/ reg cab / 4wd
1985 NISSAN TRUCK
GUNTER20
I just purchased this truck and was wandering if i could add power steering since it doesn't have it?
I was also needing to know were to get interior parts ie dash pad, sun visor hooks ect.
May 16, 2007 at 2:55 PM
KAMO
  • 47 POSTS
Yes you could add power steering, you just need to retro fit the correct parts. I believe the diesel 720's had power steering, you may be able to use the power steering assembly from that. As far as the correct parts to use, I could not tell you.
As far as interior parts, go check out your local salvage yard or search the web. Sites like www.car-parts.com or onlyfactoryparts.com are great sources for hard to find OEM parts.
May 16, 2007 at 3:26 PM
