2002 Nissan Sunny
2002 NISSAN SUNNY
FAIZAN
  • 4 POSTS
Electrical problem
2002 Nissan Sunny Automatic 123000 miles
One fine morning I have found that my Car's A/C and radiator fans (both one for A/C and one for engine cooling) was not working. I have checked all the fuses but found ok. Any help or hint will be highly appreciated...Thanks in advance :-)
Mar 22, 2009 at 7:15 AM
BMRFIXIT
  • 19,053 POSTS
Does the engine overheat ?
if not it should come on as needed
if its running hot
check coolant sensor
Mar 22, 2009 at 7:25 AM
FAIZAN
  • 4 POSTS
Thanks BMRFIXIT for a prompt reply.
Yes, the engine is getting overheat. Also the A/C has stop working and its cooling fan located at the radiator.
Mar 22, 2009 at 7:54 AM
BMRFIXIT
  • 19,053 POSTS
Check for power and ground at the coolant fan motor check for power at the relay
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_267.jpg
Mar 22, 2009 at 8:14 AM
FAIZAN
  • 4 POSTS
These relays are located with in the fuses box or in a separate box (may be a relay box)
Mar 22, 2009 at 8:47 AM
FAIZAN
  • 4 POSTS
BMRFIXIT,
I checked the relay box and found that after removing the radiator fan relay and shorting the first set of contacts found that engine fan works fine and if shorting the second set of contacts found that only A/C fan works fine but not the A/C.
Mar 22, 2009 at 10:57 AM
BMRFIXIT
  • 19,053 POSTS
A/C check its fuses again
check if full of gas (134)
fan not coming ON the test you did conform that the motor and wiring from relay to motor good
check coolant sensor and fan switch
Mar 22, 2009 at 7:43 PM
