1999 Nissan Sunny poor accleration
1999 NISSAN SUNNY
105,000 MILES • 4 CYL • FWD • MANUAL
ROBERT BOODOO
no accleration on incline.Even when the accleration pedal is depressed fully.Car is worst with a/c on.It shuts off when trying to climb hills.
Jul 10, 2010 at 9:22 AM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Jul 10, 2010 at 5:59 PM
