1994 Nissan Stanza no power
1994 NISSAN STANZA
88,000 MILES • 4 CYL • FWD • AUTOMATIC
KMUL1
My car has no power when it is first started. For the first 5minutes or so you cannot go past 10 mph. You can go a little faster after it warms. once warmed , its fine? please help. I changed fuel filters. no help
Mar 6, 2010 at 6:00 PM
Hesitating,lack of acceleration,bogging,chugging etc. could be caused by one of the following below.
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 6, 2010 at 6:03 PM
