1989 Nissan Skyline loss of oil fumes from exhaust pipe in
1989 NISSAN SKYLINE
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
QWERT557
my 89 nissan skylime has done 145,000 ks on checking the oil it has suddenly gone.
I checked for leaks and found no major leak
I refilled the oil anf found that when the engine gets hot there is smoke coming from the exhuast pipe in the engine bay.
I removed the heta garde and again checked no sign of an oil leak.The water temp seems normal.
any ideas of oil loss or smell plus smoke and fumes from exhaust pipe are of engine bay?
Aug 15, 2009 at 11:17 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will need to do a compression and leak down test, this will give you a fairly good indication as to the condition of the lower end of the engine, the excessive smoke from the breather is engine blow by, this is from worn piston rings, start here.
mark (mhpautos)
Aug 16, 2009 at 2:52 AM
