1996 Nissan Sentra Oil Change
1996 NISSAN SERENA
211,356 MILES • 4 CYL • 2WD • AUTOMATIC
LEON G
I just Change My oil while refilling, the engine with oil I spilled alot on the engine, Now i have white smoke coming out of my muffler and oil. Whats the problem?
Feb 20, 2010 at 3:28 PM
CHAOSMASTER1
  • 5 POSTS
you are most likely burning off the spilled oil, if it doesn't go away take it to the shop but do keep an eye or your oil level if it stays the same then you are just burning off the oil, check you coolant level and check for coolant in the oil or dissappearing coolant but no obvious signs of it
Mar 5, 2010 at 11:51 PM
